openHab !AUI Messages
PostPosted: Mon Mar 26, 2018 8:54 am
by Monika
I'm having some issues trying to debug an installation on openHab(2.2 specifically). My system (all wired zones) is as follows:
Ademco Vista 20p
[2] Zone expansion boards
[1] 6162 Keypad
Raspberry Pi 2b running AD image (upgraded to Stretch).
The AD WebUI shows all my zones and zone naming. I can arm/disarm successfully... On my openHab server, I can successfully telnet into AD's port 10000 (so far so good). The issue is I'm only observing !AUI messages during a zone fault. I did however see a !EXP when I closed the alarm panel cabinet door. I haven't seen any relay messages whatsoever (shouldn't I ??).
I'm hoping this is a simple config issue or you can assist me in isolating the root cause.
!CONFIG>MODE=A&CONFIGBITS=ff05&ADDRESS=19&LRR=N&COM=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
root@openHab:/etc/openhab2/services# telnet
telnet> open 10.0.9.102 10000
Connected to 10.0.9.102.
Escape character is '^]'.
[00000001000000000A--],024,[f70200ff10240000080200000010f0],"FAULT 24 CABINETTAMPER          "
!EXP:08,08,00
!AUI:120600000000666c02456cf5ec0101010000
!AUI:1606000000006763024543f531fb456cf5ec01010101
[10000001000000003A--],008,[f70200ff1008001c08020000000000],"****DISARMED****  Ready to Arm  "
!AUI:120600000000606c02456cf5ec0101010000
!AUI:1606000000006163024543f531fb456cf5ec01020106
[00000001000000000A--],002,[f70200ff1002000008020000000000],"FAULT 02 FRONT  ENTRY DOOR      "
!AUI:120600000000626c02456cf5ec0101010000
!AUI:1606000000006363024543f531fb456cf5ec01010101
Monika
Re: openHab !AUI Messages
PostPosted: Mon Mar 26, 2018 1:43 pm
by Monika
A quick follow-up to my previous post. For clarity, the faulted zone (front door) is zone #02 which is wired direct to the 20p. Deep diving I was able to find a very old thread that discussed zones 1-8 not reporting faults as !REL. So it appears that I have to do some sort of Virtual zones? Does this sound correct? I'm still searching for instructions on how and where this is performed.
PostPosted: Mon Mar 26, 2018 5:18 pm
The easiest way around this would be to hook the zones up through a zone expander which always report as !EXP messages
There is some programming fu you can do but I don't recall what it is - I seem to recall something on the old forums as well with regard to this http://archive.nutech.com/index.php?opt ... mitstart=0
PostPosted: Mon Mar 26, 2018 7:54 pm
by Monika
Thanks Kevin,
This is very disheartening. One option requires me to spend more money (and time to reprogram all 8 zones) and the other in search of someone who can help walk me through programming at least one Virtual so I feel confident enough to do the remaining zones. I guess I had hoped that there was some sort of write up in the FAQ section but other than the post you linked, there is little to no information. I don't feel like guessing my way through this one.
--Monika
kevin wrote:The easiest way around this would be to hook the zones up through a zone expander which always report as !EXP messages
PostPosted: Mon Mar 26, 2018 7:58 pm
Sorry that isn't enough information for you - I can't tell you how to program your panel as each one is different and that post does give all the necessary information to do what you're asking
What I suggest is emailing support and see if they will walk you through the process, referencing the archived posting.
PostPosted: Mon Mar 26, 2018 8:13 pm
by Monika
Actually, I owe you an apology Kevin. I didn't mean for my post to sound so strong. The information you provided was helpful, it just isn't something I feel comfortable performing on a production system. This would be a different story if I had an bench system on hand but I don't.
--Monika
kevin wrote:Sorry that isn't enough information for you - I can't tell you how to program your panel as each one is different and that post does give all the necessary information to do what you're asking
PostPosted: Mon Mar 26, 2018 8:16 pm
Email support, they may ask you to chip in to their coffee fund for the time, but they'll walk you through the process. ad2usb@support.nutech.com
PostPosted: Tue Mar 27, 2018 6:04 am
by Monika
Thanks Kevin, I emailed support with hope they can resolve this issue. If this is a case of funding coffee ... DONE ! Is this a Starbucks or Dunkin Donuts run ?
--Monika
