WebApp on OpenHabian
Postby smvsousa » Mon Apr 30, 2018 12:53 pm
Hi team,
A few weeks ago I lost my raspberry's SD card and had to reinstall everything from scratch.
Having to do that, and because I use OpenHab, I decided to use their own OS release: OpenHabian.
I did follow the WebApp installation instructions, but had to force a few software dependency versions to be able to go through the process.
I've ended up compiling everything but some stuff with warnings.
The end result is that WebApp is not working properly. Sometimes it communications with AD2USB but most of the time it doesn't. The most obvious thing is the panel status that is rarelly updated.
Did anyone install the WebApp on OpenHabian with success?
Can the AD team test WebApp on OpenHabian and let me know if/how it works?
Thank you so much,
Sérgio
smvsousa
Re: WebApp on OpenHabian
Postby kevin » Mon Apr 30, 2018 4:18 pm
Not enough resources to do this in house - that's why we provide an image - if you want to get it to work on something we don't support then you'll have to figure it out, sorry.
Users browsing this forum: No registered users and 38 guests
