Help Troubleshooting AD2Pi
My AD2Pi was was working until I had a failure on my SD card. After replacing the card and reinstalling, I am having problems I'd like help with. My guess is a wiring issue, but everything looks fine visually.
Here are the symptoms:
I'm looking for any advice on how to troubleshoot this and repair. I've replaced the Raspberry Pi thinking something happened with the GPIO interface, but that didn't help.
Thanks-
Jason
- telnetting on port 10000 DOES show a stream of messages from the Alarm panel.
- Communication appears to be one-way. No response to commands in terminal or from web app.
- Setup wizard yields:
Opening device ✔
Saving device configuration ⚠ Test timed out.
Keypad communication (Send) ⚠ Test timed out.
Keypad communication (Receive) ✔ - Web app diagnostics page returns a python error (which might be from a null response from the board?):
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1997, in __call__
File "/opt/alarmdecoder-webapp/ad2web/app.py", line 128, in __call__
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1985, in wsgi_app
response = self.handle_exception(e)
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1540, in handle_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1982, in wsgi_app
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1614, in full_dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1517, in handle_user_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1612, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1598, in dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask_login/utils.py", line 228, in decorated_view
return func(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/decorators.py", line 16, in decorated_function
return f(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/settings/views.py", line 717, in system_diagnostics
device_settings['serial'] = current_app.decoder.device.serial_number.upper()
AttributeError: 'long' object has no attribute 'upper'
Thanks-
Jason
