Newbie: AD2USB Communication is not established
Postby guimar » Tue Jun 05, 2018 12:09 pm
Hello, first of all, I have to say that I'm a newbie working with Alarms. I have just bought the AD2USB, I want to use it to communicate with a Vista 20P, what I want is to "read" every byte of data that is transmitted through ECP, I want to see RF signals information (5800 devices like a remote control 5834) even if the device is not configured on the panel, but I'm not able to do it, I cannot read anything. I think I am mssing something very basic.
When I start the app it begins to display some information on the log tab and it ends with : "!Ready. Press ! for configuration " and after that nothing happens, and the digital display stays on "Entering Running Mode Waiting first message"
This is my setup
* 1 Vista 20P
* 1 AD2USB, address 18, baud rate 115200, COM4
* 1 6150RF keypad
* 1 6160 keypad address 16
* 1 5834 remote control
* Windows 7 service pack 1, 64 bits\
* Keypadd app V2.0.10
When I arm or disarm the system using the remote, I can see the messages displayed on the 6160 keypad, I want to see the same information on the App, what am I missing?
I really appreciate your help, thanks in advance
Note: I tried to enable address 18 on the panel using field *191, options 1 1, I'm not sure if this is correct. Also, if I send '*', the log says !Sending. . . . . done
guimar
Re: Newbie: AD2USB Communication is not established
Postby kevin » Sat Jun 09, 2018 10:41 am
Sounds like you've not got your wiring correct (check di and do lines) or you have not enabled keypad address correctly in panel
