AD2USB working with Vista 20SE but not with Vista 10SE
Postby kbell152 » Fri Jul 11, 2014 11:11 am
I received my AD2USB and immediately tried it out on my Ademco Vista 20SE unit connecting to it via a Raspberry Pi and it worked! Yay!!
I then took the Rapsberry Pi with the AD2USB to my nephew's house and connected it to his Vista 10SE. Sadly it didn't work.
I verified the wiring several times and even reconnected everything thinking that maybe I had a loose connection. It’s wired as follows:
GND wired to 4
12V wired to 5
DI wired to 6
DO wired to 7
I use minicom (ver. 2.6.1) on the Raspberry Pi and can connect to the AD2USB device. I verified that the address was still set to 31 and as I needed to do with the 20SE, I set the Hardware Flow Control to No in minicom:
Serial Device : /dev/ttyUSB0
Lockfile Location : /var/lock
Callin Program :
Callout Program :
Bps/Par/Bits : 115200 8N1
Hardware Flow Control : No
Software Flow Control : No
I do not receive any messages from the 10SE alarm panel when I set the alarm to Stay from one of it's existing keypads or when I set the alarm panel to Off. When I press a key I get:
!Sending..done
or
!Sending...done
I reversed the DI and DO (I was running out of ideas) and that didn’t seem to help. It was odd though as the “!Sending..done” message seemed to respond faster. I then changed the wires back.
Attached below, I started minicom, pressed the = key to reboot the AD2USB and then hit several keys (1, 3, 4,3, 3) and then entered the ! key to get the configuration information:
pi@raspberrypi:~$ minicom -b 115200 -o -D /dev/ttyUSB0
Welcome to minicom 2.6.1
OPTIONS: I18n
Compiled on Apr 28 2012, 19:24:31.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special keys
(Here’s where I hit =)
!sn:ffffffff
!boot....................
!Ademco Keypad Emulator V2.2a.6
!Copyright (C) 2008-2010 Nu Tech Software Solutions, Inc.
!Reproduction without permission is prohibited
!By Sean Mathews <drwho at f34r.com>
!For support email general@support.nutech.com
!www.NuTech.com
!Reading configuration.
!UART init.
(Here’s where I entered 1, 3, 4,3, 3)
!Sending..done
!Sending..done
!Sending...done
!Sending...done
!Sending...done
(Here’s where I pressed the ! key)
!>Keypad Address (31) :>
!>Config Bits (ff00) :>
!>relay module #01 (N) :>
!>relay module #02 (N) :>
!>relay module #03 (N) :>
!>relay module #04 (N) :>
!>Address Filter Mask (ffffffff) :>
!>Deduplicate (N) :>
!UART init.
I've read the Quick start guide several times and watched the videos. I reviewed the FAQs and the trouble shooting guide but was not able to find anything that resolved the issue.
Unfortunately I am locked out of the Installer code. Powering on the panel and holding down the #* keys doesn't work. I need to run the Master Code finder but I can't do that until I get the AD2USB working on the 10SE. :-)
Thinking that the problem might be with the Raspberry Pi, I connected my Mac to the AD2USB and it behaved the exact same way.
Can you suggest what I should do next? I installed AlarmDecoder Keypad on my Mac but haven't been back to his house to try it yet. They live 45 minutes away. I do have remote connectivity to the unit via the rPi.
kbell152
Re: AD2USB working with Vista 20SE but not with Vista 10SE
Postby kevin » Fri Jul 11, 2014 12:24 pm
Sometimes there are some timing quirks with the older SE panels with older firmware - can you confirm that this particular SE panel has Alpha keypad support?
If you could load up the latest beta firmware from http://www.alarmdecoder.com/wiki/index.php/Firmware (2.2a.8) and enter @48 from your terminal, this will put the AD2USB into "debug" mode where it shows the bits of all communication. If you could leave @48 enabled for long enough to capture traffic (please include sending keys such as 1234 in the stream)
Copy and paste some of that output to ad2usb@support.nutech.com
You can enter @00 to exit debug mode
This will help us determine any communication issues with the 10SE panel.
Postby kbell152 » Fri Jul 11, 2014 4:39 pm
I upgraded the firmware, ran debug and sent the email.
Thanks for your help!
Ken
kbell152
Postby gottsman » Sat Jul 19, 2014 8:15 am
I also have an older 10SE panel and my AD2USB device works perfectly. If there is anything needed to help with troubleshooting, let me know..
-- Kevin
gottsman
Postby kbell152 » Sat Jul 19, 2014 8:31 am
Thanks Kevin.
I worked with Sean this week and he determined that the AD2USB appeared to be defective. I took it back to the other location and tried it on my 20SE again and now it failed on the 20SE also.
I sent it to him via USPS for repair yesterday as he requested. I'll update the ticket when I get it back.
Thanks again.
Ken
PS. I really appreciate your great support!!!
kbell152
Postby kbell152 » Thu Jul 31, 2014 5:39 am
Hi Sean,
I installed the repaired AD2USB you sent and it works great!
On a side note, I have never experienced such great customer support from a company. You were very knowledgeable and patient and resolved the issue in as little time as possible. I really appreciate your dedication to providing excellent support!!
Thanks again!
Ken
kbell152
