Download Vista 20p Configuration
Postby mrwildbob » Fri Jul 25, 2014 1:39 pm
Hello, I got my RPi & ad2usb communicating. Installed the AlarmDecoder Keypad and able to control the alarm. I am very impressed! I can not seem to figure out how to download my Vista 20p configuration. Do I need to install a module? If so, where do I get it?
thanx
boB
mrwildbob
Re: Download Vista 20p Configuration
Postby kevin » Fri Jul 25, 2014 2:06 pm
You will need to download and install our Keypad Software for PC (Windows/Mac/Linux) from here: http://www.alarmdecoder.com/wiki/index. ... der_Keypad
You will then configure it to talk to the ser2sock port on your ad2pi port 10000
You can purchase the programming downloader module from our online store - install the module in the Keypad Software once you have purchased and downloaded it, and then you can have it go through and then save your configuration
Postby mrwildbob » Fri Jul 25, 2014 6:44 pm
Hello Kevin,
Thanks for the info. I will purchase the module in a couple days. I would like to download the configuration of my current panel for backup. Is it safe to assume that I can make changes then upload back to the panel?
I really like all the work you guys have done with this software. Keep up the great work!
boB
mrwildbob
Postby kevin » Sat Jul 26, 2014 10:38 am
The module does not allow for uploading back to the panel, just allows you to back up your configuration. However, knowing all the fields and values and having them right in front of your face sure does make it easier to program from scratch.
Postby mrwildbob » Sat Jul 26, 2014 8:04 pm
Is there any plan to make an upload possible or an option in the future?
mrwildbob
Postby Scott » Mon Jul 28, 2014 10:49 am
Upload has been on our TODO list for a while, but there's a lot of subtle menu differences between panels and manufacturers. We only have a limited number of test panels in our office, so it's been made rather low priority.
Postby mrwildbob » Wed Jul 30, 2014 1:52 pm
That is understandable. I appreciate the information and the time the team puts into this project. I am willing to contribute by testing on my end and report my findings.
Thank you
boB
mrwildbob
Postby mrwildbob » Thu Aug 28, 2014 1:20 pm
After downloading the panel configuration, is there a utility to view the config? Is there a way to dump the config to a txt file with out the tags?
boB
mrwildbob
Postby kevin » Thu Aug 28, 2014 1:23 pm
The configuration is viewable within the AlarmDecoder keypad application, or via the generated xml file - currently those are the only formats it is shown.
Postby groycvg » Tue Sep 02, 2014 11:14 am
mrwildbob wrote:After downloading the panel configuration, is there a utility to view the config? Is there a way to dump the config to a txt file with out the tags?
boB
Here is a site that coverts it to Excel. It's free for small files. I uploaded the xxxxxx.config file and it gave me a nice Excel file that you can really read.
http://www.luxonsoftware.com/converter/xmltoexcel
--Greg
groycvg
