AD2PI Beta WebApp Failing Tests
Postby ritter4jp » Tue Aug 05, 2014 6:23 am
I had my system working but reloaded the software and now the tests fail at the end of setup. I used the 6-18 image with the defaults which I belive to be the same as I had done before. I can telnet to the 10000 port and talk with the board via ser2sock so that seems to work fine. I get update messages from the alarm panel while connected so that is working. I was able to type a '!' char and the setup came up and seemed to be working normally. Wouldn't I get a green check for something in the tests with that much working? What would the next step be in debugging the webapp?
ritter4jp
Re: AD2PI Beta WebApp Failing Tests
Postby kevin » Tue Aug 05, 2014 9:41 am
A look at the /var/log/gunicorn/alarmdecoder.log around that point in time would likely help in diagnosing the problem
Postby ritter4jp » Tue Aug 05, 2014 6:13 pm
I opened a putty session monitoring the log as suggested and it worked fine. I had done the same configuration many times without success. Mechanic syndrome strikes again.
Looking back in the file I ran across a Traceback that ended with wsgi.version (1,0) failed with KeyError.
Thanks for the advice.
ritter4jp
Postby Scott » Wed Aug 06, 2014 9:14 am
If you're not even getting a green check for the 'open' test I'm thinking that something was set wrong in the setup process.
The default setup is:
  • Local Device
  • /dev/ttyAMA0
  • 115200
  • Share device should be checked and configured for localhost:10000.
If that all looks good to you, send us an email at ad2usb@support.nutech.com and attach the log. I'd also be interested to see the exported settings. (Export link at the bottom of the settings page)
