alarm decoder webapp docker container
Postby codekitchen » Wed Mar 30, 2016 12:46 pm
Hey all, I created a docker container to easily get the Alarm Decoder webapp up and running (on amd64 systems), the code and instructions for using are at https://github.com/codekitchen/alarmdec ... dockerfile
I'm using this in my home automation setup which is all built and deployed using a docker-compose recipe. The AlarmDecoder container doesn't contain nginx, I use a separate nginx-proxy container to proxy Alarm Decoder, Domoticz and a few other apps, with SSL client cert verification configured.
I've only tested this with the AD2USB hardware.
codekitchen
Return to Code Contributions
