Support for older Ademco 4150
Postby oedo808 » Thu Dec 10, 2015 3:33 pm
Does this support an older alarm system? We bought the house last year and it already has this installed. I hope it's supported, I've been looking off and on for a year for a way to use this without paying a company!
Sent from my Nexus 6 using Tapatalk
oedo808
Re: Support for older Ademco 4150
Postby oedo808 » Thu Dec 10, 2015 3:34 pm
Control panels are way older than the photos shown.
oedo808
Postby kevin » Thu Dec 10, 2015 3:39 pm
We do support older alarm panels - however, this one is non-compatible as it doesn't even have alpha display support.
Postby oedo808 » Thu Dec 10, 2015 3:41 pm
I was about to just buy the rPi version outright until I started looking at the panels and how much newer they look than mine. I've been waiting to pull the trigger on starting home automation for a year until I found out whether or not I could get it to work with my existing security system. I was so excited earlier when I saw this supported Ademco but when I saw 90s and later this evening I choked. It kind of looked like I had the same pins for positive and ground as the one in the video but I am just not sure.
oedo808
Postby oedo808 » Thu Dec 10, 2015 3:57 pm
Also here is the picture of the wiring diagram.. I'm a little worried because I don't see a DI DO which I would assume is digital in and digital out :-(
oedo808
Postby kevin » Thu Dec 10, 2015 3:59 pm
The alarmdecoder will connect to your panel, it will just not relay messages properly due to protocol incompatibilities.
Postby oedo808 » Fri Dec 11, 2015 5:49 am
Thanks for the response.
oedo808
Postby oedo808 » Fri Dec 11, 2015 6:54 am
One more question because you guys seem to be really awesome and very knowledgeable with this, and I really want to give you money.. It seems to me that I can buy a Vista 20p panel, a 6160 keypad, and a battery for like $130. From what I've read the hardwired sensors are pretty much compatible with anything so they should work fine. I might need to replace a component or two if they're defective but all in all it doesn't seem like that bad of price and easy installation because everything is already wired. Then it's just a $70 board from you guys and I'm in business with a much more up to date alarm system anyways. Do you think I would run into any speed bumps replacing my panel and keypad? I'm fairly confident in my ability to follow wiring diagrams, it can't be much more difficult than adding a rain/temp sensor to my irrigation system, as long as I'm not going to run into any compatibility issues. Thanks for all of the help!
oedo808
Postby oedo808 » Fri Dec 11, 2015 7:11 am
The Google seems to believe that programming the Vista 20p is a pain for the end user, but I found this https://www.alarmgrid.com/faq/how-do-you-program-a-honeywell-vista-20p-alarm-control-panel guide and along with the instructions and a youtube video or two I can probably manage it.
oedo808
Postby kevin » Fri Dec 11, 2015 10:45 am
If you're comfortable with wiring things and comfortable being methodical with your keypresses, an upgrade to a vista20p, in my opinion is not that bad. You're right on the cost, not too hefty, and yes, most of the sensors should be compatible - but easily replaceable piecemeal if not. The hardest part is programming, but the programming manuals are pretty good and there are lots of tutorials out there.
Users browsing this forum: No registered users and 34 guests
