The file modified is types.py in /opt/alarmdecoder-webapp/ad2web/notifications/
Step 1) back up the original module as a failsafe by copying it to types.py.org
Step 2) add
import datetime
Step 3) find the following section of code and add the bit between the modification comments (it should take up only one line in the file; use space key before text to align it as seen below):
def send(self, type, **kwargs):
errors = []
for id, n in self._notifiers.iteritems():
if n and n.subscribes_to(type, **kwargs):
try:
message = self._build_message(type, **kwargs)
if message:
#modification ->
message = message + " [" + datetime.datetime.now().strftime("%I:%M:%S%p %Z %a %m/%d/%y") + "]"
#modification <-
if n.delay > 0 and type in (ZONE_FAULT, ZONE_RESTORE, BYPASS):
Step 4) reboot the machine running the web app.
It should just work after that and will append "<message text> [hh:mm:ssAM|PM Dow mm/dd/yy]". The %Z was to insert the time zone, but that apparently isn't defined in the AD python raspberry Pi image implementation - or I missed something obvious as I'm new to python - and so doesn't appear.
