After running for years.Restarted w/ fresh Image..NO GO!
Postby wilsonb » Fri Jun 29, 2018 9:25 am
Was up and running for years. Something broke with WebServer.. not able to get help to resolve. Trying to start over.
Raspberry Pi B+
Latest Raspberry Pi image 2018-05-29
Familiar with Raspberry initial setup.
Background...
Followed steps from here with new image;
http://www.alarmdecoder.com/wiki/index.php/Raspberry_Pi
Steps not clear / confusing because some items already done with image. Seems instructions need to be updated.
"7.) Boot it up again.
At this point you should be able to communicate with the device at /dev/ttyAMA0.
No link or explanation how to test the communication w/ device.
"The AlarmDecoder WEB App install instructions are here
https://github.com/nutechsoftware/alarmdecoder-webapp "
Looked at, but ASSUMING not necessary with new image.
_____________
Current issue:
LEAVING out of town.
Seems some services are not running by default. When going to AlarmD webserver, it says;
Services might still be starting - please wait and try again. If this continues, please let us know on GitHub. You can also email us at Support
wilsonb
Re: After running for years.Restarted w/ fresh Image..NO GO
Postby wilsonb » Fri Jun 29, 2018 10:23 am
Seems some services are not starting. How to find which one? or start one by one?
Alarm Decoder webapp not working.JPG (40.71 KiB) Viewed 9259 times
wilsonb
Postby kevin » Fri Jun 29, 2018 3:46 pm
Not sure what you're trying to accompli9sh. If you're using the image, all you have to do is hit the webpage and go through setup. Instructions for manual install don't apply to the image.
If you're still having trouble, I suggest emailing support.
Postby jasonsf » Fri Jun 29, 2018 7:15 pm
One thing that kept giving me problems was that I updated the files for Alarmdecoder from git but never ran the setup to install the updates. If you update through the web app, it does it for you, but if you did a git pull then you need to run python setup.py install from within the /opt/Alarmdecoder folder.
Jason
jasonsf
Postby wilsonb » Fri Jun 29, 2018 7:25 pm
Long Story short.. I think the new released image is not compatible with older Raspberry B+
I started over using latest image but am now using Raspberry Pi 3
How to reset configuration to default? There is no "Factory Default" option.
Rename a setup file somewhere?
Also,
I still get Python errors.
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1836, in __call__
File "/opt/alarmdecoder-webapp/ad2web/app.py", line 128, in __call__
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1820, in wsgi_app
response = self.make_response(self.handle_exception(e))
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1403, in handle_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1817, in wsgi_app
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1477, in full_dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1381, in handle_user_exception
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1475, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1461, in dispatch_request
File "/usr/local/lib/python2.7/dist-packages/flask_login.py", line 792, in decorated_view
return func(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/decorators.py", line 16, in decorated_function
return f(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/settings/views.py", line 717, in system_diagnostics
device_settings['serial'] = current_app.decoder.device.serial_number.upper()
AttributeError: 'long' object has no attribute 'upper'
The debugger caught an exception in your WSGI application. You can now look at the traceback which led to the error.
wilsonb
Postby jasonsf » Fri Jun 29, 2018 7:32 pm
You can delete the sqlite.db and run a reset script. Search for resetting the database. I don't remember the command offhand. I'll see if I can find it.
Sent from my Pixel 2 using Tapatalk
jasonsf
Postby jasonsf » Fri Jun 29, 2018 7:33 pm
Here it is:
cd /opt/alarmdecoder-webapp
sudo rm instance/db.sqlite
python manage.py initdb
sudo reboot
jasonsf
Postby wilsonb » Fri Jun 29, 2018 9:22 pm
Thanks..
Was up and running..
But now.. urrgrrg getting so pissed.
Now im getting the stupid 502 Bad Gateway
and now..
Services might still be starting - please wait and try again. If this continues, please let us know on GitHub. You can also email us at Support.
wilsonb
Postby jasonsf » Fri Jun 29, 2018 9:34 pm
I know how frustrating that is. I went through it. I replaced my pi because communication wasn't working. I'm currently running via the docker image. Like I said earlier, I needed to run the AlarmDecoder installer to fix my issues.
jasonsf
Postby wilsonb » Fri Jun 29, 2018 10:06 pm
Ran that but still no joy..
I tried running
sudo python setup.py install
from within the /opt/Alarmdecoder (reboot) & alarmdecoder-webbapp folder (reboot).
Still 502 Bad Gateway
Sign in
Here is the log results;
File "/opt/alarmdecoder-webapp/ad2web/discovery.py", line 96, in run
self._update()
File "/opt/alarmdecoder-webapp/ad2web/discovery.py", line 111, in _update
address = self._get_ip_address()
File "/opt/alarmdecoder-webapp/ad2web/discovery.py", line 183, in _get_ip_address
default_gateway = gateways['default'][netifaces.AF_INET]
KeyError: 2
2018-06-30 01:23:55,707 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:55,712 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:55,716 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:55,721 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:55,768 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:56,046 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:56,094 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:56,188 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:56,308 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:23:56,326 ERROR: Error in DiscoveryServer: 2 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:99]
self._update()
KeyError: 2
2018-06-30 01:27:19,526 INFO: Checking for version updates - last check at: 06-30-2018 01:16:28 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 01:33:54,793 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 01:33:54,847 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
File "/opt/alarmdecoder-webapp/ad2web/app.py", line 168, in init_app
app.decoder.init()
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 242, in init
self._discovery_thread = DiscoveryServer(self)
File "/opt/alarmdecoder-webapp/ad2web/discovery.py", line 60, in __init__
sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, mreq)
File "<string>", line 1, in setsockopt
error: [Errno 19] No such device
2018-06-30 01:37:38,716 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 01:37:38,772 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 01:46:01,761 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 01:46:01,815 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 01:52:55,725 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 01:52:55,781 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 01:56:08,832 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 01:57:15,372 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 01:57:17,333 INFO: Event: Ready status has changed to False [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 01:57:17,981 INFO: Event: !LRR:000,1,DSC_1801,00 [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 01:57:41,777 INFO: Event: Ready status has changed to True [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 01:59:14,913 INFO: Event: Ready status has changed to False [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 01:59:14,968 INFO: Event: The alarm system has been armed AWAY. [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 01:59:20,119 INFO: Event: Ready status has changed to True [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 01:59:20,186 INFO: Event: The alarm system has been disarmed. [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 02:02:34,827 ERROR: Import Error: not a gzip file [in /opt/alarmdecoder-webapp/ad2web/settings/views.py:650]
2018-06-30 02:03:38,258 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:07:15,385 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 851, in on_keypress
self._alarmdecoder.device.send(key)
AttributeError: 'Decoder' object has no attribute 'device'
2018-06-30 02:07:18,490 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:31,218 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:31,799 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:32,019 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:32,443 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:32,648 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:33,110 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:33,476 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:33,712 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:45,931 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:46,604 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:47,315 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:47,823 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:49,353 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:49,977 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:50,594 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:07:51,088 ERROR: Error sending keypress to device [in /opt/alarmdecoder-webapp/ad2web/decoder.py:854]
2018-06-30 02:09:47,068 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:09:47,134 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 240, in init
self._notifier_system = NotificationSystem()
File "/opt/alarmdecoder-webapp/ad2web/notifications/types.py", line 88, in __init__
self._init_notifiers()
File "/opt/alarmdecoder-webapp/ad2web/notifications/types.py", line 214, in _init_notifiers
self._notifiers[n.id] = TYPE_MAP[n.type](n)
File "/opt/alarmdecoder-webapp/ad2web/notifications/types.py", line 927, in __init__
self.auth_username = self.auth_username.replace('\n', '')
AttributeError: 'NoneType' object has no attribute 'replace'
2018-06-30 02:10:13,915 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:10:40,666 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:11:01,657 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:11:08,167 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:11:10,273 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:11:27,713 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:12:17,803 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:12:17,868 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 02:13:11,788 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:13:21,645 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:13:24,043 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:13:33,679 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:13:41,211 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:13:43,722 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:13:44,288 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:13:59,899 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:14:29,713 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:14:50,014 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:15:20,212 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:15:40,338 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:16:57,330 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:17:52,058 INFO: AlarmDecoder device was closed. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:403]
2018-06-30 02:17:57,670 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:18:33,402 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:19:07,014 INFO: AlarmDecoder device was closed. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:403]
2018-06-30 02:19:11,539 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:20:05,872 INFO: AlarmDecoder device was closed. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:403]
2018-06-30 02:20:37,645 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:25:29,770 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:25:29,836 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 02:31:45,760 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:31:45,828 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 02:31:48,092 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:31:48,180 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 02:44:15,038 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:44:15,151 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 02:47:32,304 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:47:32,376 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 02:49:57,975 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:50:09,839 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:50:20,671 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:50:27,784 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 02:53:24,713 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:59:19,293 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 02:59:19,364 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 03:01:50,356 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 03:01:50,425 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 03:09:23,467 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 03:09:23,535 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 03:13:25,927 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 03:13:25,995 ERROR: Error [in /opt/alarmdecoder-webapp/ad2web/app.py:175]
app.decoder.init()
2018-06-30 03:18:54,030 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:19:14,955 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:19:45,852 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:39:34,619 INFO: AlarmDecoder device was closed. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:403]
2018-06-30 03:41:39,662 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:41:56,885 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:46:29,131 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 03:46:29,247 INFO: Discovery running: loc=192.168.1.72:5000, uuid=2bdffabd-7c18-11e8-b108-b827eb5fa898 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:70]
2018-06-30 03:46:29,342 INFO: Set export parameters to: server localhost port 25 tls False auth False from root@alarmdecoder frequency 0 store files False storage path /opt/alarmdecoder-webapp/instance/exports days to keep files 7 email enable False [in /opt/alarmdecoder-webapp/ad2web/decoder.py:709]
2018-06-30 03:46:29,363 INFO: Checking for version updates - last check at: 01-01-1970 00:00:00 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 03:48:05,936 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:48:10,986 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:48:47,395 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:49:13,340 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:49:15,101 INFO: Event: Ready status has changed to False [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 03:49:15,829 INFO: Event: Received LRR / Contact ID event [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 03:49:42,206 INFO: Event: Ready status has changed to True [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 03:56:51,513 INFO: Checking for version updates - last check at: 06-30-2018 03:46:29 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 03:57:23,336 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 03:57:25,212 INFO: Event: Ready status has changed to False [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 03:57:25,870 INFO: Event: Received LRR / Contact ID event [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 03:57:52,330 INFO: Event: Ready status has changed to True [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 04:06:53,920 INFO: Checking for version updates - last check at: 06-30-2018 03:56:51 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 04:10:13,967 ERROR: Import Error: not a gzip file [in /opt/alarmdecoder-webapp/ad2web/settings/views.py:650]
2018-06-30 04:11:45,767 ERROR: Import Error: not a gzip file [in /opt/alarmdecoder-webapp/ad2web/settings/views.py:650]
2018-06-30 04:16:56,372 INFO: Checking for version updates - last check at: 06-30-2018 04:06:53 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 04:19:59,992 INFO: AlarmDecoder device was closed. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:403]
2018-06-30 04:20:04,992 INFO: Attempting to reconnect to the AlarmDecoder [in /opt/alarmdecoder-webapp/ad2web/decoder.py:533]
2018-06-30 04:20:05,069 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 04:20:33,507 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 04:20:35,392 INFO: Event: Ready status has changed to False [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 04:20:36,064 INFO: Event: Received LRR / Contact ID event [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 04:21:02,463 INFO: Event: Ready status has changed to True [in /opt/alarmdecoder-webapp/ad2web/notifications/types.py:371]
2018-06-30 04:26:59,162 INFO: Checking for version updates - last check at: 06-30-2018 04:16:56 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 04:27:30,886 ERROR: Import Error: not a gzip file [in /opt/alarmdecoder-webapp/ad2web/settings/views.py:650]
2018-06-30 04:30:01,570 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 04:30:07,600 INFO: Attempting to reconnect to the AlarmDecoder [in /opt/alarmdecoder-webapp/ad2web/decoder.py:533]
2018-06-30 04:30:07,652 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 04:37:12,542 INFO: Checking for version updates - last check at: 06-30-2018 04:26:59 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 04:42:54,120 INFO: AlarmDecoder Webapp booting up - v0.8.2-0-g0664184 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:222]
2018-06-30 04:42:54,153 INFO: Discovery running: loc=192.168.1.72:5000, uuid=2bdffabd-7c18-11e8-b108-b827eb5fa898 [in /opt/alarmdecoder-webapp/ad2web/discovery.py:70]
2018-06-30 04:42:54,249 INFO: Set export parameters to: server localhost port 25 tls False auth False from root@alarmdecoder frequency 0 store files False storage path /opt/alarmdecoder-webapp/instance/exports days to keep files 7 email enable False [in /opt/alarmdecoder-webapp/ad2web/decoder.py:709]
2018-06-30 04:42:54,270 INFO: Successfully imported backup file. [in /opt/alarmdecoder-webapp/ad2web/settings/views.py:644]
2018-06-30 04:42:57,707 INFO: Attempting to reconnect to the AlarmDecoder [in /opt/alarmdecoder-webapp/ad2web/decoder.py:533]
2018-06-30 04:42:57,887 INFO: AlarmDecoder device was opened. [in /opt/alarmdecoder-webapp/ad2web/decoder.py:391]
2018-06-30 04:47:30,479 INFO: Checking for version updates - last check at: 06-30-2018 04:37:12 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
2018-06-30 04:57:32,845 INFO: Checking for version updates - last check at: 06-30-2018 04:47:30 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:608]
wilsonb
Users browsing this forum: No registered users and 30 guests
