I have several ideas as to what you are seeing but I need logs to confirm.
Please send at least 20 or 30 lines of messages from your panel so I can see what is happening.
- logs.jpg (184.04 KiB) Viewed 9896 times
You say you removed a keypad to swap in the AD2*. Not a problem in most cases but if that keypad was also a RF transmitter / Keypad combo then you way see all your zones go poof if they are RF zones. Just one thought.
Also be sure to send me your settings from your AD2* Easy way is to telnet in and press a capital C command and hit enter. But on the keypad app it is also shown.
- settings.jpg (151.69 KiB) Viewed 9896 times
