I've read the wiki information on flashing the firmware as found here, as well as some posts that I found on the topic.
I've never had to flash the device (I bought at version 2.2a.8.8, so I'm not sure if my confusion is because the URL above is trying to convey the multiple ways one can flash, and I'm reading too much into it.
If the User is using the WebApp to update the firmware on a Raspberry Pi, is the process different than what's on the URL? I can't imagine asking the user to run an update via webapp, then have them ssh in to reset the device via a serial prompt, then go back to the web to update.
In short, my question is:
If the User is flashing via the WebApp, what are steps? I assume:
- Use webapp to export copy of config
- Flash via webapp
- Does the webapp do an automated config reset at this point?
- If yes, I understand User has to do a "next next" setup to get through config, and load the config exported above.
- If no, is there a need to do a reset or an import of the config?
Really appreciate it!
