Hello -
I recently moved and installed a new vista 20p alarm panel. I moved the ad2usb and pi 3b+ from my prior residence where it worked flawlessly for several years. Recently my alarm decoder started showing a “alarm decoder has booted successfully” message every two hours in the logs. The device appears to function correctly until that point. After the boot message, the web app shows the “please wait... loading” message and basically becomes non responsive (I can still navigate around the webapp, but it does not respond to keypad presses or events coming from the panel) until I do a hard reboot on the pi at which point the process starts all over again. The only oddity in the logs of the webapp are this periodic boot message.
I’ve flashed the sd card several times with the latest pifactory build as well as upgrading (which seemed to make things worse). Any assistance would be greatly appreciated.
