Debian 11 support?
Debian 11 support?
Postby edrikk » Sat Aug 28, 2021 2:31 pm
As far as I understand, AD does not support Python 3.
With Debian 11 removing Python 2, is there any chance of/timeline for AD being patched to support python 3, or is the platform at a dead end with Debian 10?
edrikk
Re: Debian 11 support?
Postby mathewss » Tue Sep 07, 2021 9:59 am
It will happen eventually but not sure when. I have LTS support on the current distribution Buster for several more years so I had not put this into a priority state 'yet'. I am looking for anyone willing to do the work in porting and I would be willing to help fund such work as I am currently tied up on the new IoT C++ embedded API code for the rest of this year. Next year likely I will have more time and be willing to switch from C++ to Python for a few months :)
Postby edrikk » Sat Jan 07, 2023 2:04 pm
Hi there @mathewss
It seems Debian Buster will no longer be receiving security updates.
Any chance some time could be spent in updating the webui so that we can do a dist-upgrade to Debian 11?
mathewss wrote:It will happen eventually but not sure when. I have LTS support on the current distribution Buster for several more years so I had not put this into a priority state 'yet'. I am looking for anyone willing to do the work in porting and I would be willing to help fund such work as I am currently tied up on the new IoT C++ embedded API code for the rest of this year. Next year likely I will have more time and be willing to switch from C++ to Python for a few months :)
edrikk
Postby mathewss » Fri Feb 17, 2023 12:49 pm
Unfortunately this update will require more time than I have currently. The core Python code is one problem and then we have the gunicorn web code that will require a lot of changes to work.
What services do you use? I have a new C++ API and am considering a port to run on any Linux system. Just looking for what parts are needed most so I can prioritize.
Postby edrikk » Fri Mar 24, 2023 4:43 pm
Thanks! That would be amazing as it would streamline codebase (ie fixes) and allow for the underlying OS to update as well!
I’m terms of services being use, that’s a harder one to answer as I use HomeAssistant https://www.home-assistant.io/integrations/alarmdecoder/ to integrate with AD. I’m not sure what services that depends on, although I assume Ser2Sock is a major one.
From a WebUI perspective I only check to see if there any firmware or git updates.
edrikk
Postby edrikk » Tue Jul 04, 2023 5:18 am
mathewss wrote:Unfortunately this update will require more time than I have currently. The core Python code is one problem and then we have the gunicorn web code that will require a lot of changes to work.
Hi @mathewss
To add, I have recently switched to HomeBridge, and it uses the "Notifications" functionality of Alarm Decoder.
Just wondering what your thoughts are on this / if there is any thoughts one when this could be at least updated to Debian 12 now which was just released on LTS Kernel 6.1.
edrikk
Postby edrikk » Tue Jul 04, 2023 5:19 am
Hi again,
edrikk
Users browsing this forum: No registered users and 4 guests
