Hit * for faults - multi-partition
Postby miragejb » Wed Aug 18, 2021 9:12 am
I am having problem expanding the faults when I get the "Hit * for faults" message (Honeywell 21ip). If I launch a telnet window and type in "K19*" and hit enter, it seems to have no effect. I am using the "K" command to associate the "*" with keypad 19 in hopes that it will expand the messages.
I have two partitions and need to direct the "*" command to that specific keypad.
I am running firmware version 2.2a.8.8. I have tried the Beta version 2.2a.8.9b-306 as well, but it doesn't seem to help. Has anyone got this to work? I've seen a couple of posts regarding it, but nothing seems to help.
Thanks-in-advance.
miragejb
Re: Hit * for faults - multi-partition
Postby mathewss » Tue Sep 07, 2021 10:03 am
Sorry for the late reply. This should work something else must be happening. I am exclusively using the 'K' command on the new C++ IoT embedded API code and it has been working perfectly.
A few things is it possible you are hitting or sending a \r or \n after the K command? The K command persists until it receives a \r\n and then it reverts back to the default address.
https://github.com/nutechsoftware/AlarmDecoder-IoT/blob/zone-tracking/main/ad2_utils.cpp#L1003
Sean M.
Postby miragejb » Tue Sep 07, 2021 10:20 am
Thanks Sean. I am out of town at the moment but will give it a try as soon as I am able.
I'm pretty sure I tried it without the "\r\n". It wasn't working when I sent the command: K19* (K <command> + 19 <keypad address> + *) as follows:
if(message.ToLower().Contains("hit * for faults"))
    Logger.LogDebug("Sending message to display detail fault information");
     var command = $"K{int.Parse(alarmDecoderMessage.Keypads[0]):00}*"; //HERE IS THE COMMAND
     await _socketTransceiver.SendAsync(command.ToAsciiBytes(), CancellationToken.None);
     Task.Delay(500, CancellationToken.None).Wait(CancellationToken.None);
I'll let you know how it goes.
miragejb
Postby mathewss » Tue Sep 07, 2021 11:04 am
Looks correct. Took me a minute to get my brain back into C# mode and interpolation :c)
Looks correct presuming that in the array[0] the int keypad value. It looks to send "K19*"
Stick with the latest firmware. It is possible some issues exist in 8.8
When you dig in again give me a ring or drop an email. One idea is to enable verbose logging on ser2sock. It is a bit noisy but you will see raw bytes received from the client and it may show something. As I recall ANY character not expected by my code on the AD2* will kick it out of the K mode but it would have no issues accepting the initial command "K19*".
Postby miragejb » Wed Sep 08, 2021 9:26 am
What is the latest version of the AD2USB firmware?
miragejb
Postby mathewss » Wed Sep 08, 2021 1:27 pm
The latest is 2.2a.8.9 here is the link. It has a few small fixes to 8.8
http://www.alarmdecoder.com/downloads/firmware/2.2/ademcoemu_V2-2a-8-9b-306.zip
Postby miragejb » Thu Sep 09, 2021 4:21 am
Again, Thank you very much.
I'll give it try next week.
miragejb
Postby miragejb » Mon Sep 13, 2021 9:30 am
Well. I updated the AD2USB to the version you suggested. I still can't get the details of the "Hit * for faults".
The correct Keypad is 19 and I am sending "K19*". I have also tried "K19*\r", "K19*\n" and "K19*\r\n", but it's just not working. I've tried through code and manually using Telnet.
I also tried the AlarmDecoder Keypad App (V2.0.10), but hitting * on it doesn't work as well.
Can you think of anything else that might help?
Thanks-in-advance.
miragejb
Postby mathewss » Mon Sep 13, 2021 9:49 am
A few ideas yes.
If you can turn on debugging by sending @48 then type your K command and send me 30 or so lines of messages from the AD2* when this is done.
1) Another keypad is at 19
2) 19 is not enabled on the partition that has a fault.
A few lines of messages from the panel so I can see the keypads that are enabled would help and again above the debug dump while sending will show if another keypad is on that same address.
will look something like this. This was me sending K01 to my 50PUL panel.
[01010001000100003A--],0fc,[f700000000fc804c0c020000202020],"SYSTEM LOBAT                    "
!DBG:<ff><ff><ff><ff><ff>
!DBG:*f7*[f7][07][00][16][00][fc][80][0c][0c][02][00][00][c1][52][4d][45][44][20][2a][2a]
!DBG:[2a][41][57][41][59][2a][2a][2a][2a][2a][20][41][4c][4c][20][53][45][43][55][52][45]
!DBG:[20][2a][2a][77]<ff>
[01010001000000003A--],0fc,[f707001600fc800c0c0200002a2a2a],"ARMED ***AWAY***** ALL SECURE **"
!DBG:<ff><ff><ff><ff><ff><ff><ff>
!DBG:*f7*[f7][00][00][00][00][fc][80][0c][0c][02][00][00][d3][59][53][54][45][4d][20][4c]
!DBG:[4f][42][41][54][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20]
!DBG:[20][20][20][fc]<ff>
[01010001000000003A--],0fc,[f700000000fc800c0c020000202020],"SYSTEM LOBAT                    "
!DBG:<ff><ff><ff>
!Sending.!DBG:(fd)<ff>
!DBG:*f6*[f6][01](01)(02)(0a)(f3)[01]done
!DBG:<ff>
!DBG:*f7*[f7][07][00][16][00][fc][80][00][0c][02][00][00][c3][4f][4d][4d][2e][20][46][41]
!DBG:[49][4c][55][52][45][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20][20]
!DBG:[20][20][20][00]
Users browsing this forum: Google [Bot] and 3 guests
