I just noticed that when there is an Envisalink 4 on the ECP buss of my Vista20-P, I can't connect to the panel using Compass. However, the virtual Keypad works fine.
I can overcome the problem by temporarily disconnecting the data wires at the Envisalink terminal block. In addition to the Envisalink (4 located inside the panel enclosure), I have a 6160 keypad located about 15" from the panel and a 6160RF located about 12 feet away. From all this, I'm assuming that the keypads on the ECP buss use a much lower data rate than Compass so the virtual keypad works fine but the I/O ports on the Envisalink board are loading the buss just enough to reduce the bandwidth of the buss and thereby preventing Compass from communicating.
Is this a known issue? Is there another (better) workaround?
rlmnky
