[Solved] ad2usbgui doesn't create log file
Postby bradrel » Sat Jan 18, 2014 5:26 am
I have the ad2usbgui running on a Raspberry Pi and it doesn't appear to be creating a log file. The entries show up in the "Log" section of the GUI, however there is no ad2usbgui.log in /var/log/
Thanks in advance.
Brad
bradrel
Re: ad2usbgui doesn't create log file
Postby mathewss » Sat Jan 18, 2014 8:27 am
The default location for the log is in the same folder as the program. You can try and move it adding the full path and file name to the config for logging but permissions may be in the way.
Postby bradrel » Sun Jan 19, 2014 6:25 am
mathewss wrote:The default location for the log is in the same folder as the program. You can try and move it adding the full path and file name to the config for logging but permissions may be in the way.
Unfortunately there is no log in that directory either.
bradrel
Postby mathewss » Sun Jan 19, 2014 8:40 am
Odd. Ok lets try this. Zip up your GUI folder and email it back to me to review. Send it to general@support.nutech.com
Postby mathewss » Sun Jan 19, 2014 8:12 pm
This looks like a bug in version 2.0.6 Update to the latest version 2.0.8 and give it a try.
I do not currently have a zip file download for the Pi but you can install it onto a windows computer and then transfer the AlarmDecoder folder to your Raspberry Pi. You should be able to run the Linux installer on the Pi if you have a JVM installed but I have not tested this myself.
Let me know if it is a problem to install on the Pi and I will provide a solution.
Postby bradrel » Mon Jan 20, 2014 10:47 am
Latest version fixed the issue.
Brad
bradrel
Users browsing this forum: No registered users and 37 guests
