I have been working on getting a python script working with my new AD2USB. I am able to extract and parse RFX messages using the python module, however I am not able to get any zone tracking events or events such as on_arm or on_disarm.
Here is the script I am using to test with, it outputs nothing at all to the referenced log file.
import time, logging
from alarmdecoder import AlarmDecoder
from alarmdecoder.devices import USBDevice
# Global Variables
LOG_FILE = 'alarm_state.log'
def main():
try:
# Setup and begin logging
logging.basicConfig(filename=LOG_FILE, level=logging.INFO, format='%(asctime)s %(message)s', datefmt='%m/%d/%Y %H:%M:%S')
logging.info('---------- Starting log ----------')
# Retrieve the first USB device
device = AlarmDecoder(USBDevice.find())
# Set up an event handler and open the device
device.on_zone_fault += handle_zone_fault
device.on_zone_restore += handle_zone_restore
device.on_arm += handle_arm
device.on_disarm += handle_disarm
with device.open():
while True:
time.sleep(1)
except Exception, ex:
logging.error('Exception:'+str(ex))
def handle_zone_fault(sender, zone):
logging.info('Zone Fault:'+str(zone))
def handle_zone_restore(sender, zone):
logging.info('Zone Restored:'+str(zone))
def handle_arm(sender):
logging.info('System Armed')
def handle_disarm(sender):
logging.info('System Disarmed')
if __name__ == '__main__':
main()
Here is the output from the AD2USB device directly, while faulting a zone and restoring it. Curiously, I get a series of keypad messages, one stating everything is in the ready state and another telling me the zone is faulted, both while the zone is in the faulted state.
!Ademco Keypad Emulator V2.2a.6
!Copyright (C) 2008-2010 Nu Tech Software Solutions, Inc.
!Reproduction without permission is prohibited
!By Sean Mathews <drwho at f34r.com>
!For support email general@support.nutech.com
!www.NuTech.com
!Ready. Press ! for configuration.
[1000000110000000----],008,[f70000031008001c28020000000000]," DISARMED CHIME Ready to Arm "
[1000000110000000----],008,[f70000040008001c28020000000000]," DISARMED CHIME Ready to Arm "
!RFX:0206723,80
[0000030110000000----],010,[f70000011010030028020000000000],"FAULT 10 BACK DOOR "
[0000000110000000----],010,[f70000020010000028020000000000],"FAULT 10 BACK DOOR "
[0000000110000000----],008,[f70000031008000c28020000000000]," DISARMED CHIME Hit * for faults"
The AD2USB is has the default configuration and I am using a Vista 20P. Can someone provide guidance on where I may be going wrong?
Robert
