REL | NNNNN | [YN]{4} | Emulation of relay expanders 1-4 |
If you send ! followed by a carriage return you will be prompted for each field. This prompt also includes a basic description of the setting as well as it's current value.
You may hit enter to keep the current value or enter a new one.
Programmatically
You may retrieve all of the devices settings by sending C to the panel followed by a carriage return (\r).
Retrieving AlarmDecoder settings:
