Code | Description |
15 | Indicates an issue with a zone |
17 | Unused |
18 | Unused |
This is the binary message data associated with the message. It includes all of the bit field entries that were separated out for you in the first field, as well as the rest of the message for debugging and exploratory purposes.
There is one important piece of data included in this field: the keypad address mask that the message is intended for.
The four bytes starting at position 2 (zero-indexed) represent the mask.
- f70700060010808c08020000
Our keypad address mask is 07000600.
Inside this mask each bit represents a specific keypad.
