Code | Description |
15 | Indicates an issue with a zone |
17 | Unused |
18 | Unused |
There is one important piece of data included only in this field: the keypad address mask that the message is intended for.
The four bytes starting at position 2 (zero-indexed) represent the address mask, which indicates which keypads should be receiving this message.
The address mask details only become really important when you're working with a setup that has multiple partitions, since the AlarmDecoder will see all messages by default.
