Revision as of 15:20, 18 December 2013 by 204.10.16.29 (Talk)
17 Unused
18 Unused
1 Unknown
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
Keypad Address
