What is LRR?
LRR refers to a long-range radio system that sends messages to an external network.
LRR provides several advantages:
- The User ID of the person who triggered the message is provided.
- Ability to receive notification of a PANIC.
- Simplifies detecting of specific alarm events with better granularity.
These messages can be made visible to the AlarmDecoder either using a physical radio device or by enabling emulation in the configuration.
How do I enable LRR?
- Check your panel programming, which is likely field *29.
- If it's already enabled:
- You're already set up for LRR. Proceed to Step #2.
- If not:
- Enable the field on the panel
- If you don't have an LRR device then you'll need to enable emulation on the AlarmDecoder:
- Connect to your AlarmDecoder with a terminal. (PuTTY, screen, etc.)
- Send !
- Go through the configuration prompts and enable support for LRR emulation.
- Enable any reporting fields you want to receive. The ALARM_* events are always enabled. See the table below for the others.
