Supported Panels
Revision as of 17:09, 20 December 2013 by 204.10.16.29 (Talk)
Ademco / Honeywell Systems
The AlarmDecoder was designed to work with any alarm from the Ademco/Honeywell Vista series from the 90's right up to the latest 2013 Honeywell Vista 21IP and more recently DSC Power series alarms. This document will help identify if a given panel is compatible with the AlarmDecoder. Many of these alarm panels were sold under different names branded by the alarm monitoring company for example Safewatch Pro 3000/3000CN which is actually a Vista 20P.
  • Note: The Ademco LYNX Systems are NOT compatible as they do not support the 4 wire expansion bus the AlarmDecoder connects to.
If after reading this you still are not sure if your panel is supported and are interested in the AlarmDecoder then send us an email with a picture of your alarm panel filling the full frame of your camera and we will check it out. (Please provide a general statement of release for the photo as we may use them on the website to help others.)
Keypads
The AlarmDecoder is compatible with any alarm that is also compatible with one of these Ademco/Honeywell keypads.
5839
6127 & 6129
6138
>6139
6148
6150
6150RF
6160CR
6160
6160V
6164
6270
6271V
6128
6128RF
Panels
This is a partial list. Many supported panels were sold under different names and model numbers so here are some tips for seeing if your panel will be compatible.
  • Look for a large wiring sticker inside the panel enclosure that shows the word(s): Vista, Ademco, Honeywell, etc.
  • Look on the panel for words like SAVS and a series of letters and numbers like SAVS20P5 or SAVS10SECE. The model number is embedded inside this string of characters as demonstrated here.
Vista 10SE
Vista 20P
Vista 30SE
Vista 21IP
Vista 128BP
Vista 10P
Vista 15P
Vista 20SE
We now support the DSC Power series alarm panels. This requires beta firmware 2.2a.8 or later. This is still in beta and new features are being added every month.
Panels
DSC Power 432/ PC-580
DSC Power 632 / PC-1555
DSC Power 832 / PC-5010
DSC Power 864 / PC-5020
