The current stable firmware is V2.2a.6. It is not possible to brick the AlarmDecoder but it can get into some states that make firmware updates difficult so be patient when updating the firmware in your AlarmDecoder.
Board Revision | Firmware Version |
Stable | |
2.2+ | 2.2a.6 |
2.0 | 2.1f.10 |
Beta | |
2.2+ | 2.2a.8 |
Legacy | |
2.2+ | 2.2a.3-beta |
2.2+ | 2.2a.2 |
2.0 | 2.1f.0e |
2.0 | 2.1f.0d |
2.0 | 1.0f.26 |
- Flash the firmware
