Revision as of 13:41, 1 May 2014 by 204.10.16.29 (Talk)
  • Disabled serial console so that the device can use it.
  • Installed ser2sock to expose the AlarmDecoder on your network.
  • Installed the AlarmDecoder Python library.
  • Installed and configured Avahi.
Link Version MD5
Download 2014-05-01 0302cf2c27eab5176e8a56bcffc65d83
