Revision as of 15:05, 16 May 2014 by 204.10.16.29 (Talk)
Stable Download 2014-05-01 0302cf2c27eab5176e8a56bcffc65d83 Pre-configured with ser2sock
Beta Download 2014-05-16 0f196658f30dda7a64625ffcc6825f61 Pre-configured with ser2sock & webapp
Build the next IoT device
File:PiGPIO IOT.zip
