- Installed and configured Avahi.
- Beta: Installed and configured the AlarmDecoder Webapp.
Status | Link | Version | MD5 | Includes |
Stable | Download | 2014-05-01 | 0302cf2c27eab5176e8a56bcffc65d83 | Pre-configured with ser2sock |
Beta | Download | 2014-05-16 | 0f196658f30dda7a64625ffcc6825f61 | Pre-configured with ser2sock & webapp |
Build the next IoT device
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
