Revision as of 12:22, 18 June 2014 by 204.10.16.29 (Talk)
IoT webapp architecture
Stable Download 2014-05-01 0302cf2c27eab5176e8a56bcffc65d83 Pre-configured with ser2sock
Beta Download 2014-06-18 36f68d4eca8f03cdd05aa2c9bb70d3d5 Pre-configured with ser2sock & webapp
Build the next IoT device
File:PiGPIO IOT.zip
Login
pi
Password
raspberry
Login
admin
Password
alarmdecoder
