Revision as of 14:41, 18 August 2014 by 204.10.16.29 (Talk)
IoT webapp architecture
Stable Download 2014-05-01 0302cf2c27eab5176e8a56bcffc65d83 Pre-configured with ser2sock
Beta Download 2014-08-18 1a34fdbc4b81b81a8c758fd6be4dbb2f Pre-configured with ser2sock & webapp. Supports the Raspberry Pi Model B+.
Build the next IoT device
File:PiGPIO IOT.zip
Login
pi
Password
raspberry
Login
admin
Password
alarmdecoder
