- Beta: Installed and configured the AlarmDecoder Webapp.
- Beta: Supports the new Raspberry Pi Model B+.
Status | Link | Version | MD5 | Includes |
Stable | Download | 2014-05-01 | 0302cf2c27eab5176e8a56bcffc65d83 | Pre-configured with ser2sock |
Beta | Download | 2014-08-18 | 1a34fdbc4b81b81a8c758fd6be4dbb2f | Pre-configured with ser2sock & webapp. Supports the Raspberry Pi Model B+. |
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
