Revision as of 09:56, 20 May 2015 by 204.10.16.29 (Talk)
Once the AlarmDecoder WebApp is started you may connect to the Application via a web browser and pointing the URL to http://alarmdecoder.local - if this name resolution fails and you are on a Windows System, please download Bonjour For Windows and try again. This will take you to our first setup screens which will be detailed below.
  • Local Device means the device is connected to the same computer running the WebApp
  • Network Device means you have already exposed an AlarmDecoder via ser2sock
