Revision as of 12:21, 20 May 2015 by 204.10.16.29 (Talk)
Once the AlarmDecoder WebApp is started you may connect to the Application via a web browser and pointing the URL to http://alarmdecoder.local - if this name resolution fails and you are on a Windows System, please download Bonjour For Windows and try again. This will take you to our first setup screens which will be detailed below.
  • Local Device means the device is connected to the same computer running the WebApp
  • Network Device means you have already exposed an AlarmDecoder via ser2sock
Make sure to set your address correctly! 31 for SE Panels, and for 20P Panels you will have to program an address spot into your panel and assign the AlarmDecoder the newly enabled address.
