Revision as of 14:40, 20 May 2015 by 204.10.16.29 (Talk)
Once the AlarmDecoder WebApp is started you may connect to the Application via a web browser and pointing the URL to http://alarmdecoder.local - if this name resolution fails and you are on a Windows System, please download Bonjour For Windows and try again. This will take you to our first setup screens which will be detailed below.
#Configure Device
Coming soon...
