Revision as of 13:47, 20 May 2015 by 204.10.16.29 (Talk)
Once the AlarmDecoder WebApp is started you may connect to the Application via a web browser and pointing the URL to http://alarmdecoder.local - if this name resolution fails and you are on a Windows System, please download Bonjour For Windows and try again. This will take you to our first setup screens which will be detailed below. The device is initially configured for DHCP.
Coming soon...
