Revision as of 11:31, 21 May 2015 by 204.10.16.29 (Talk)
Keypad Interface
Main Notification Interface
List of Notification Types
Email
Example of Twilio Notification Configuration
Here is an example of a Twilio Notification configuration
  • Account SID - Your Twilio Account SID
  • Auth Token - Your Twilio User Auth Token
  • To - Number to Send SMS to
  • From - Your valid Twilio Phone Number
Example of Google Talk Notification Configuration
Here is an example of a Google Talk Notification configuration
  • Source Address - Messages will come FROM this address
  • Password - The password for the SOURCE account
  • Destination Address - Messages will go to this address
Example of Pushover.net Notification Configuration
Here is the configuration for a Pushover.net notification
  • API Token - The API Token provided by Pushover for your User
  • User/Group Key - The User or Group Key for your account at Pushover
  • Message Priority - In what priority do you want alarm panel notifications
  • Title of Message - Messages sent to Pushover are titled with this text
Example of Prowl Notification Configuration
Here is an example of a Prowl notification configuration
  • API Key - Your Prowl API Key
  • Application Name - Application to Show in Notifications
  • Message Priority - What priority do you want alarm panel notifications to come through as
Example of NotifyMyAndroid configuration
Here is an example of a NotifyMyAndroid notification configuration
  • API Key - Your NotifyMyAndroid API Key
  • Application Name - Application Name to show in notifications
  • Message Priority - What priority do you want Alarm Panel notifications to come through?
Example Coming soon..
