- Multiple User Accounts
- Per-user notifications
- IP Camera integration
- Support for PC/Mac/Linux as well as Mobile and Tablet browsers
- The AlarmDecoder WebApp Keypad Interface
- Click "Start!" to continue
- ser2sock Port is different from the HTTP/WSGI ports - do not choose 80, 443, or 5000.
- Once you are logged in, go to Settings and click on Notifications. From there, you can edit already configured notifications or click "New Notification" to create a new notification.
- This is the main interface for creating and listing notifications. Here you can choose to create new or edit existing notifications.
- Here is a list of all current supported notification types.
- Here is a list of all of the events that can trigger a notification. You are able to select which ones you would like to see. You can also have different notification types alert you for different kinds of notifications. This interface is common to all notification types.
- Here is an example email notification form using gmail settings for example
- Source Address - Emails appear "From" this address
- Destination Address - Emails will go "To" this address
- Email Subject - Emails will contain this subject line
- Email Server - The server to connect to when sending emails
- Server Port - The port of the email server to connect to
- Use TLS? - Enable Transport Layer Security for the session
- Authenticate with email server? - If a username and password is required by the email server to send, supply them
- Username - Your email username
- Password - Your email password
- Here is an example of a Twilio Notification configuration
- Account SID - Your Twilio Account SID
- Auth Token - Your Twilio User Auth Token
- To - Number to Send SMS to
- From - Your valid Twilio Phone Number
- Here is an example of a Google Talk Notification configuration
- Source Address - Messages will come FROM this address
- Password - The password for the SOURCE account
- Destination Address - Messages will go to this address
- Here is the configuration for a Pushover.net notification
- API Token - The API Token provided by Pushover for your User
- User/Group Key - The User or Group Key for your account at Pushover
- Message Priority - In what priority do you want alarm panel notifications
- Title of Message - Messages sent to Pushover are titled with this text
- Here is an example of a Prowl notification configuration
- API Key - Your Prowl API Key
- Application Name - Application to Show in Notifications
- Message Priority - What priority do you want alarm panel notifications to come through as
- Here is an example of a NotifyMyAndroid notification configuration
- API Key - Your NotifyMyAndroid API Key
- Application Name - Application Name to show in notifications
- Message Priority - What priority do you want Alarm Panel notifications to come through?
- An example of a Growl Notification configuration
- Hostname - The Growl server to send notification to
- Port - The Growl Server Port
- Password - The password for the Growl server
- Title - Notification Title
- Message Priority - What priority do you want these messages to come through as?
- Here is an example configuration for a Custom POST notification
- POST URL - URL of server to POST data to
- POST Path - Location on server from URL to post to
- SSL? - Is the URL SSL or Not
- POST Type - urlencoded, JSON, or XML POST types supported
- Custom Values - Here you are able to create your own key/value pairs to send with your notification
- If you are not using our image, or an older version of the image, you must perform a few steps to enable Camera Support
- in the contrib directory of the webapp there is an opencv directory
- in the opencv directory execute
- sudo sh opencv.sh
- Once this is done and installed, you can then configure and view a camera.
- Here you see the interface where it lists current cameras as well as a button for creating a new camera.
- Here we are creating a camera for view in the system
- Name - The name of the camera for display purposes
- Snapshot URL - The full URL of the motion jpeg stream for your IP camera
- Username - The username for authenticating to the camera
- Password - The password for authenticating to the camera
