Revision as of 11:47, 26 May 2015 by 204.10.16.29 (Talk)
  • Support for PC/Mac/Linux as well as Mobile and Tablet browsers
Keypad Interface
Main Notification Interface
List of Notification Types
Email
Example of Twilio Notification Configuration
Here is an example of a Twilio Notification configuration
  • Account SID - Your Twilio Account SID
  • Auth Token - Your Twilio User Auth Token
  • To - Number to Send SMS to
  • From - Your valid Twilio Phone Number
Example of Google Talk Notification Configuration
Here is an example of a Google Talk Notification configuration
  • Source Address - Messages will come FROM this address
  • Password - The password for the SOURCE account
  • Destination Address - Messages will go to this address
Example of Pushover.net Notification Configuration
Here is the configuration for a Pushover.net notification
  • API Token - The API Token provided by Pushover for your User
  • User/Group Key - The User or Group Key for your account at Pushover
  • Message Priority - In what priority do you want alarm panel notifications
  • Title of Message - Messages sent to Pushover are titled with this text
Example of Prowl Notification Configuration
Here is an example of a Prowl notification configuration
  • API Key - Your Prowl API Key
  • Application Name - Application to Show in Notifications
  • Message Priority - What priority do you want alarm panel notifications to come through as
Example of NotifyMyAndroid configuration
Here is an example of a NotifyMyAndroid notification configuration
  • API Key - Your NotifyMyAndroid API Key
  • Application Name - Application Name to show in notifications
  • Message Priority - What priority do you want Alarm Panel notifications to come through?
Example of a Growl Notification
An example of a Growl Notification configuration
  • Hostname - The Growl server to send notification to
  • Port - The Growl Server Port
  • Password - The password for the Growl server
  • Title - Notification Title
  • Message Priority - What priority do you want these messages to come through as?
Example of a Custom POST notification
Here is an example configuration for a Custom POST notification
  • POST URL - URL of server to POST data to
  • POST Path - Location on server from URL to post to
  • SSL? - Is the URL SSL or Not
  • POST Type - urlencoded, JSON, or XML POST types supported
  • Custom Values - Here you are able to create your own key/value pairs to send with your notification
If you are not using our image, or an older version of the image, you must perform a few steps to enable Camera Support
  • in the contrib directory of the webapp there is an opencv directory
  • in the opencv directory execute
    • sudo sh opencv.sh
  • Once this is done and installed, you can then configure and view a camera.
Example of Camera Listings
Here you see the interface where it lists current cameras as well as a button for creating a new camera.
Example of Creating Camera
Here we are creating a camera for view in the system
  • Name - The name of the camera for display purposes
  • Snapshot URL - The full URL of the motion jpeg stream for your IP camera
  • Username - The username for authenticating to the camera
  • Password - The password for authenticating to the camera
Host Settings
Found under settings->Host
Example of Host Settings Page
Here you are able to configure your device's hostname, networking, as well as reboot and shutdown the device.
