Code | Description |
17 | Unused |
18 | Unused |
Header | AUI Data | ||
!KPE:18 | |||
Header | Keypad Address | ||
!KPE | 18 |
!ERR:0 | |||
Header | Error list | ||
!ERR | 1,1,1 |
Keypad Address
