Revision as of 11:30, 8 September 2015 by 204.10.16.29 (Talk)
15 Indicates a system issue
17 Unused
18 Unused
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
 !ERR Format
!ERR:0
Header Error list
 !ERR 1,1,1
Keypad Address
  • Boot flash mode
  • Operating mode
  • Error mode
