K | Send message from specific partition or keypad address. Addressed Message |
- K011234\r
- K1912343\r
Code | Description |
[00110011000000003A--],010,[f70700000010808c18020000000000],"ARMED ***STAY** ZONE BYPASSED " | |||
[00110011000000003A--] | 010 | [f70700000010808c18020000000000] | "ARMED ***STAY** ZONE BYPASSED " |
17 | System specific error report |
18 | Ademco or DSC Mode A or D |
Header | AUI Data | ||
!KPE:18 | |||
Header | Keypad Address | ||
!KPE | 18 |
!ERR:0 | |||
Header | Error list | ||
!ERR | 1,1,1 |
Keypad Address
