AlarmDecoder Modem
Revision as of 15:08, 15 January 2016 by 204.10.16.29 (Talk)
Introduction
FAQ
Is your panel supported?
Confirming your panel model and revision
Vista 20P
Revision 7.0
List of supported panels
Panel Compatibility
Manufacturer Model Revision
Vista 10P 2.0+
Vista 10PSIA 3.0+
Vista 15P 5.2+
Vista 20P / 20PSIA 5.2+
First Alert FA130CP 2.0+
First Alert FA130CPSIA 3.0+
First Alert FA148CP / FA148CPSIA 5.2+
First Alert FA168CPS / FA168CPSSIA 5.2+
While it's technically possible you could make things work without knowing the installer code for your panel, there are a number of things that may need to be changed in the panel programming.
If your panel is currently or was previously monitored you'll likely need to either obtain the CSID and Account # from your alarm company or reset the dialer settings to factory default. This can typically be done by executing *96 while in programming mode.
Again, this is technically possible, but you'd need to convince your alarm company to provide you with the CSID and Account # on your panel.
Does this support ADT branded panels?
Unfortunately ADT utilizes a custom default CSID so it can't be used without knowing what this is. To our knowledge this is undocumented. In theory you may be able to swap the PROM, but this is untested.
Where can I get Compass®?
Compass is available for download on the internet, though we cannot provide any direct links.
Setup & Configuration
  1. Download the AlarmDecoder Modem software using the link provided in your order email.
  2. Run the installer. This will install the modem and any necessary prerequisites.
    • Enter your product key when prompted.
  3. Make sure that all keypad applications, terminal clients or other software accessing the AlarmDecoder is closed. One connection is allowed at a time.
  4. Configure the AlarmDecoder Modem
    1. Run the AlarmDecoder Modem Setup from your Start Menu.
      1. Choose your AlarmDecoder Modem COM port from the first dropdown box.
        • You should make a note of this for later.
      2. Select USB, Serial or Network to indicate the type and location of your AlarmDecoder device.
        • If USB or Serial: Select the correct AlarmDecoder COM port.
        • If Network: Fill in the name or IP address of the computer (or AD2PI) that's running the ser2sock service.
          • Note: This service is preinstalled on our pre-configured Raspbian disk images.
      3. Click Save
  5. Configure Compass®
    1. Create a new modem
      • Compass® 1.x:
        1. Select the AlarmDecoder Modem Comm port (from the first dropdown) as your COM port.
      • Compass® 2.x:
        1. Click Configure COM ports
        2. Choose your AlarmDecoder Modem COM port from the list and click Add.
        3. Close the window and select the port in the list.
    2. Configure the modem
      • Compass® 1.x:
        1. Select Ademco for the Company
        2. Select Accura 336 as your modem type.
      • Compass® 2.x:
        1. Select Ademco/First Alert for the Company.
        2. Select Ademco CIA 2400 as your modem type.
    3. Open (or create) as Customer
    4. Open the Communications screen
    5. Test your modem connection
      1. Set the panel phone number to whatever you prefer. It is required but ignored.
      2. Uncheck the Answering Machine Defeat checkbox.
      3. Select the proper CSID setting for your install.
        • First Time Communication: Select this if your panel has a default CSID. (Field 36)
          • Acct # in Panel: Select this option if the Acct # has been programmed on your panel. (Field 32) The Account number in Compass® much match.
      4. Click Connect
Using The Modem
Troubleshooting
Connection to panel failed
Panel too old
Check the revision of your panel by following the instructions <here>.
Incorrect CSID
Factory state - default CSID:
CSID set:
Please contact support at alarmdecoder@support.nutech.com and we'll help you figure out what's going on.
Getting Help
If you have issues with the software please feel free to contact us at alarmdecoder@support.nutech.com or post in our forums.
  • Operating system
  • Panel model
  • Panel revision
