Introduction
FAQ
Is your panel supported?
Manufacturer | Model | Revision |
Vista | 10P | 2.0+ |
Vista | 10PSIA | 3.0+ |
Vista | 15P | 5.2+ |
Vista | 20P / 20PSIA | 5.2+ |
First Alert | FA130CP | 2.0+ |
First Alert | FA130CPSIA | 3.0+ |
First Alert | FA148CP / FA148CPSIA | 5.2+ |
First Alert | FA168CPS / FA168CPSSIA | 5.2+ |
Where can I get Compass®?
Setup & Configuration
- Download the AlarmDecoder Modem software using the link provided in your order email.
- Run the installer. This will install the modem and any necessary prerequisites.
- Make sure that all keypad applications, terminal clients or other software accessing the AlarmDecoder is closed. One connection is allowed at a time unless you're using the network interface.
- Click Save
- Configure Compass®
- Create a new modem
- Compass® 1.x:
- Select the AlarmDecoder Modem COM port (from the first dropdown) as your COM port.
- Compass® 2.x:
- Click Configure COM ports
- Compass® 1.x:
- Configure the modem
- Compass® 1.x:
- Compass® 2.x:
- Compass® 1.x:
- Open (or create) a Customer
- Test your modem connection
- First Time Communication: Select this if your panel has a default CSID. (Field 36)
- Acct # in Panel: Select this option if the Account number has been programmed on your panel. (Field 32) The Account number in Compass® much match.
- Click Connect
Using The Modem
Troubleshooting
Connection to panel failed
Panel too old
Incorrect CSID
Factory state - default CSID:
CSID set:
Getting Help
- Operating system
- Panel model
- Panel revision
