Setup Vera
Revision as of 13:19, 4 March 2016 by 10.10.0.9 (Talk)
Vera
Setup For Network Appliance
  • Install AD2USB Plugin (It creates 2 devices, 1 for Panel, 1 for Partition)
  • Upload latest, patched L_VistaAlarmPanel1.lua from http://forum.micasaverde.com/index.php/topic,26672.msg272946.html#msg272946
  • On the panel device add the overNetwork setting manually:
    • Panel device -> Advanced -> New Service
      • New Service: urn:micasaverde-com:serviceId:VistaAlarmPanel1
      • New Variable: overNetwork
      • New Value: 1
    • Click 'add'
    • Click 'Reload'
  • On the panel device change the 'ip' variable to the ser2sock ip:port from your raspberry pi (ex: 192.168.1.100:10000)
  • On the partition device set the KeypadAddresses variable to your keypad address.
Issue going to ready mode after alarm fault
  • On the panel device add the DisableSendStar variable
      • New Variable: DisableSendStar
      • New Value: 1
    • Click 'add'
    • Click 'Reload'
