Supported Panels
Revision as of 14:05, 8 March 2016 by 10.10.0.5 (Talk)
Ademco / Honeywell Systems
The AlarmDecoder was designed to work with any alarm from the Ademco/Honeywell Vista series from the 90's right up to the latest 2013 Honeywell Vista 21IP and more recently DSC Power series alarms. This document will help identify if a given panel is compatible with the AlarmDecoder. Many of these alarm panels were sold under different names branded by the alarm monitoring company for example Safewatch Pro 3000/3000CN which is actually a Vista 20P.
  • Note: The Ademco LYNX Systems are NOT compatible as they do not support the 4 wire expansion bus the AlarmDecoder connects to.
If after reading this you still are not sure if your panel is supported and are interested in the AlarmDecoder then send us an email with a picture of your alarm panel filling the full frame of your camera and we will check it out. (Please provide a general statement of release for the photo as we may use them on the website to help others.)
Keypads
The AlarmDecoder is compatible with any alarm that is also compatible with one of these Ademco/Honeywell keypads.
5839
6127 & 6129
6138
>6139
6148
6150
6150RF
6160CR
6160
6160V
6164
6270
6271V
6128
6128RF
LYNX Touch(L5100)
Panels
This is a partial list. Many supported panels were sold under different names and model numbers so here are some tips for seeing if your panel will be compatible.
  • Look for a large wiring sticker inside the panel enclosure that shows the word(s): Vista, Ademco, Honeywell, etc.
  • Look on the panel for words like SAVS and a series of letters and numbers like SAVS20P5 or SAVS10SECE. The model number is embedded inside this string of characters as demonstrated here.
Vista 10SE/VIA-30PSE
Vista 10P Plus Series
Vista 15
Vista 15P Plus Series
Vista 20P
Vista 20PUL
Vista 20SE
Vista 21iP
Vista 30SE
Vista 40
Vista 50P
Vista 50PUL
Vista 128BP
Vista 128B Series
Vista-128BPT/Vista Turbo Series
Vista 128FBP
Vista 250BP
Vista 250BPT/Vista Turbo Series
Vista 250FBP
First Alert FA-168C & Others
Safewatch 3000
†Honeywell Lynx 3000 Plus
† The "Honeywell Lynx 3000 Plus" panel is supported but requires additional work to connect. No other Lynx panels work with AlarmDecoder at this time.
We now support the DSC Power series alarm panels. This requires beta firmware 2.2a.8 or later. This is still in beta and new features are being added every month.
Panels
DSC Power 432/ PC-580
PC1404
DSC Power 632 / PC-1555
DSC PowerSeries Control Panel PC1616
DSC PowerSeries Control Panel PC1832
DSC PowerSeries Control Panel PC1864
DSC Power 832 / PC-5010
DSC Power 864 / PC-5020
PC5100
PC5108
PC5200
PC5204
PC5208
PC5320
PC5400
PC5950
