K | Send message from specific partition or keypad address. Addressed Message |
- K011234\r
- K1912343\r
Code | Description |
[00110011000000003A--],010,[f70700000010808c18020000000000],"ARMED ***STAY** ZONE BYPASSED " | |||
[00110011000000003A--] | 010 | [f70700000010808c18020000000000] | "ARMED ***STAY** ZONE BYPASSED " |
17 | System specific error report |
18 | Ademco or DSC Mode A or D |
Header | AUI Data | ||
!KPE:18 | |||
Header | Keypad Address | ||
!KPE | 18 |
!ERR:4,4,4 | |||
Header | Error list | ||
!ERR | 4,4,4 |
Error number | Description | ||
0 | No issues to report | ||
4 | Keypress send failure |
!VER:ffffffff,V2.2a.8.2,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER | |||
Header | Serial number | Firmware version | Firmware capabilities |
!VER | ffffffff | V2.2a.8.2 | TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER |
Firmware Capabilities | |||
Flag | Description | ||
TX | Ability to transmit to the panel | ||
RX | Ability to receive from the panel | ||
SM | Supports sending multiple keypresses | ||
VZ | Virtual zone expanders | ||
RF | Supports receiving of RF messages from the 5800 series wireless devices (!RFX) | ||
ZX | Supports receiving of messages from zone expanders (!EXP) | ||
RE | Supports receiving of messages from relay (!REL) | ||
AU | AUI support (!AUI) | ||
3X | Special Keys (F1-F4) must be sent 3 times to trigger | ||
CG | Serialized configuration string | ||
DD | Message deduplication | ||
MF | Address mask filter | ||
LR | Long range radio messages (!LRR) | ||
KE | Keypad event messages (!KPM) | ||
MK | Multiple keypad emulation (See 'K' command for more information) | ||
CB | Config bits | ||
DS | DSC support | ||
ER | Error tracking |
