Revision as of 13:59, 7 February 2017 by 10.10.0.31 (Talk)
\x01\x01\x01 Send Special Key #1
\x02\x02\x02 Send Special Key #2
\x03\x03\x03 Send Special Key #3
\x04\x04\x04 Send Special Key #4
\x05\x05\x05 Send Special Key #5
\x06\x06\x06 Send Special Key #6
\x07\x07\x07 Send Special Key #7
\x08\x08\x08 Send Special Key #8
a DSC ONLY(deprecated use Special Keys): Arm Away
s DSC ONLY(deprecated use Special Keys): Arm Stay
c DSC ONLY(deprecated use Special Keys): Toggle Chime
  • K011234\r
  • K1912343\r
Special Keys
Special Key Codes
Code Description Ademco DSC
\x01\x01\x01 Special Key #1 Fire/Prog. Fire
\x02\x02\x02 Special Key #2 Police/Prog. Police
\x03\x03\x03 Special Key #3 Medical/AUX/Prog. Medical/AUX
\x04\x04\x04 Special Key #4 Programmable Stay
\x05\x05\x05 Special Key #5 N/A Away
\x06\x06\x06 Special Key #6 N/A Chime
\x07\x07\x07 Special Key #7 N/A Reset
\x08\x08\x08 Special Key #8 N/A Exit
15 Indicates a system issue
17 System specific error report
18 Ademco or DSC Mode A or D
 !AUI Format
Header AUI Data
 !KPE Format
!KPE:18
Header Keypad Address
 !KPE 18
 !ERR Format
!ERR:4,4,4
Header Error list
 !ERR 4,4,4
Error number Description
0 No issues to report
4 Keypress send failure
 !VER Format
 !VER Format
Flag Description
VZ Virtual zone expanders
AU AUI support (!AUI)
3X Special Keys (S1-S4) must be sent 3 times to trigger
DD Message deduplication
MF Address mask filter
LR Long range radio messages (!LRR)
CB Config bits
DS DSC support
ER Error tracking
  • Boot flash mode
  • Operating mode
  • Error mode
