K | Send message from specific partition or keypad address. Addressed Message |
R | Host Acknowledge the CRC message was valid. |
\x01\x01\x01 | Send Special Key #1 |
\x02\x02\x02 | Send Special Key #2 |
\x03\x03\x03 | Send Special Key #3 |
\x04\x04\x04 | Send Special Key #4 |
\x05\x05\x05 | Send Special Key #5 |
\x06\x06\x06 | Send Special Key #6 |
\x07\x07\x07 | Send Special Key #7 |
\x08\x08\x08 | Send Special Key #8 |
a | DSC ONLY(deprecated use Special Keys): Arm Away |
s | DSC ONLY(deprecated use Special Keys): Arm Stay |
c | DSC ONLY(deprecated use Special Keys): Toggle Chime |
0123456789*#<> | Send key to panel |
- K011234\r
- K1912343\r
Special Keys
Code | Description | Ademco | DSC |
\x01\x01\x01 | Special Key #1 | Fire/Prog. | Fire |
\x02\x02\x02 | Special Key #2 | Police/Prog. | Police |
\x03\x03\x03 | Special Key #3 | Medical/AUX/Prog. | Medical/AUX |
\x04\x04\x04 | Special Key #4 | Programmable | Stay |
\x05\x05\x05 | Special Key #5 | N/A | Away |
\x06\x06\x06 | Special Key #6 | N/A | Chime |
\x07\x07\x07 | Special Key #7 | N/A | Reset |
\x08\x08\x08 | Special Key #8 | N/A | Exit |
[00110011000000003A--],010,[f70700000010808c18020000000000],"ARMED ***STAY** ZONE BYPASSED " | |||
[00110011000000003A--] | 010 | [f70700000010808c18020000000000] | "ARMED ***STAY** ZONE BYPASSED " |
17 | System specific bits. 4 bits packed into a HEX Nibble [0-9,A-F] |
18 | Ademco or DSC Mode A or D |
Header | AUI Data | ||
!KPE:18 | |||
Header | Keypad Address | ||
!KPE | 18 |
!ERR:4,4,4 | |||
Header | Error list | ||
!ERR | 4,4,4 |
Error number | Description | ||
0 | No issues to report | ||
4 | Keypress send failure |
!VER:ffffffff,V2.2a.8.2,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER | |||
Header | Serial number | Firmware version | Firmware capabilities |
!VER | ffffffff | V2.2a.8.2 | TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;LR;KE;MK;CB;DS;ER |
Firmware Capabilities | |||
Flag | Description | ||
TX | Ability to transmit to the panel | ||
RX | Ability to receive from the panel | ||
SM | Supports sending multiple keypresses | ||
VZ | Virtual zone expanders | ||
RF | Supports receiving of RF messages from the 5800 series wireless devices (!RFX) | ||
ZX | Supports receiving of messages from zone expanders (!EXP) | ||
RE | Supports receiving of messages from relay (!REL) | ||
AU | AUI support (!AUI) | ||
3X | Special Keys (S1-S4) must be sent 3 times to trigger | ||
CG | Serialized configuration string | ||
DD | Message deduplication | ||
MF | Address mask filter | ||
LR | Long range radio messages (!LRR) deprecated see L2 | ||
L2 | Long range radio messages (!LRR) with CID reporting format | ||
KE | Keypad event messages (!KPM) | ||
MK | Multiple keypad emulation (See 'K' command for more information) | ||
CB | Config bits | ||
DS | DSC support | ||
ER | Error tracking | ||
CR | CRC Wrapper around EXP,LRR and other event type messages |
