Status | Link | Version | MD5 | Includes | |
Stable | Download | 2016-04-29 | ce5a33fe64535b8ecf526e6e5c9bf356 | Pre-configured with webapp. Supports the Raspberry Pi Model B, B+ and B2, and B3. Wifi and Bluetooth are both functional on the Pi 3. | |
Beta | Download | 2018-04-15 | 472f6cf18d61c22bc78a3dcc34f8028e | 2018-04-15 updated to support Pi 3B+ fixup_cd.dat, fixup.dat, fixup_db.dat, fixup_x.dat, start_cd.elf, start_db.elf, start.elf, start_x.elf, AlarmDecoder 1.13.3, AlarmDecoder-webapp 0.8.1 (needs testing) |
- Login
- pi
- Password
- raspberry
- Login
- admin
- Password
- alarmdecoder
